Front suspensions rattles over bumps
Old Jul 3, 2001 | 10:19 PM
Stormshadow GTA's Avatar
the noise ****' me off it rattles over everything,what should i do.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Old Jul 4, 2001 | 02:25 PM
DSouthern's Avatar
Stormshadow
Check your front brake pads. The clip that holds the brake pad tight against the caliper piston may have come loose. This happened on my car and it rattled on every little bump.
Just pull your front wheels off and check the brake pads, if they are loose it will be pretty obvious.
Old Jul 4, 2001 | 03:30 PM
86SCBNJ's Avatar
Anither source of rattling can be your strut mounts. If the bearings are worn, they will make a rattling noise like the front end is loose....
Old Jul 5, 2001 | 12:50 AM
PROCHARGED89Z's Avatar
Check those front calipers.They are well known to rattle when going over bumps when they are worn/and or loose.
customblackbird
Aug 15, 2021 10:16 PM
cam-mike
Aug 24, 2015 07:23 AM
mustangman65_79
Aug 8, 2015 12:07 PM
