Springs
Old Jul 10, 2001 | 12:36 PM
Ovrclck350's Avatar
Springs
Will 4th gen Springs fit on a 2nd gen? I know this isn't a 3rd gen ?, but if anyone knows, it'll help out a lot.
Old Jul 10, 2001 | 01:27 PM
orange rocket's Avatar
Does the front have coil overs like a 4th gen? is the rear setup just like a 3rd gen? The rears work on third gens so...
Old Jul 10, 2001 | 04:28 PM
FloridaRacer's Avatar
if you want 2nd gen springs go to www.stockcarproducts.com they lower your car about 2".. but you can choose your spring rate and are about $60 a pair...
i have a 2nd gen that i use to autocross, check out my webpage if you need any info on it..
FloridaRacer.com
Old Jul 10, 2001 | 04:31 PM
Tas's Avatar
Tas
no.
Old Jul 10, 2001 | 11:24 PM
No?? No what??? Are the springs the same? or no to the lowering ones!
Old Jul 11, 2001 | 04:39 PM
kevinc's Avatar
Car: 1982 Z28
2nd gens use leaf springs in the rear, and coils up front.
4th gens use coils all around, and the front geometry is significantly different than a 2nd gen.
The fronts **MAY** fit, but the rates will be way off.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Jul 11, 2001 | 07:48 PM
Sorry. I was stupid for a minute. Forgot about raer leafs. I wouldn't go near a 4th gen front. Get a proper one for the front. Remember the Ls1 is all aluminum and the panels are all plastic/ fiberglass. Alot lighter.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
