Removed steering play - wow!
Old Jul 15, 2001 | 07:04 AM
Frank88's Avatar
I just did this on my '88 GTA. It had a bad idler arm which I had changed-out, then aligned. This improved the steering quite a bit, as it was pretty bad. Last night I removed the steering play and what a difference it makes! Took out almost one turn and it's a new car! Highly recommended.
Old Jul 15, 2001 | 08:55 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Cool, i also have crappy steering. What exactily did you do? Just replace the idler arm, and have the front end aligned?
Thanks!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Old Jul 15, 2001 | 10:41 PM
Hulk0202's Avatar
I think hes probably talking about the nut on top of the steering box that you can do to take out some of the play. You have to hold the bolt with an allen wrench, loosen the nut, the turn the bolt down a bit.
Old Jul 16, 2001 | 06:02 PM
Frank88's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Hulk0202:
I think hes probably talking about the nut on top of the steering box that you can do to take out some of the play. You have to hold the bolt with an allen wrench, loosen the nut, the turn the bolt down a bit.</font>
Correct. The idler arm had a lot of very obvious wear and the car would react strangely when going over bumps. The steering play adjustment is as Hulk0202 described. You have to be careful not to overdo it as you can damage the steering box.
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
wild1
Aug 27, 2015 09:01 AM
3rdgenparts
Aug 8, 2015 07:09 PM
