I need new rotors please help!
Old Jul 22, 2001 | 06:52 PM
Casey'91Z28's Avatar
As I was replacing my brake pads I checked the rotor thickness and mine were under the limit of .965 in. The driver side was .955 and the passenger side was .945, so I have decided to purchase new rotors. But I figured why not upgrade to some better ones. So which rotors could I get that work with stock calipers and pads? I dont want to spend over $250 but I do want some high quality ones? Any opinions on GT rotors, Powerslot, or Autospecialty? Should I get cross drilled, slotted or just flat ones? I just want something that will increase the performance for doing some canyon carving and maybe an open track day once in a while? I have front discs and rear drums.
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, SLP 1 5/8" headers, catco 3" cat, 14.7@ 93 mph(need new times after exhaust)
[This message has been edited by Casey'91Z28 (edited July 22, 2001).]
Old Jul 22, 2001 | 07:29 PM
Jza's Avatar
Jza
The only rotors that are going to perceptively increase your braking performance are larger diameter rotors, but you'd need to convert in order to do that, and that's obviously out of your stated budget!
That said, I use Autospecialties Powerstop cross-drilled rotors on the front, and I've had them for about a problem-free year and a half. There was no increase in performance (though I wasn't expecting any), I just needed something better looking because I have these 17 inch wheels that are almost all void. They'll serve me find until I can upgrade the entire braking system.
Those rotors were $150 for the pair.
Old Jul 22, 2001 | 09:48 PM
Intense92's Avatar
Jza is right, you won't really be able to tell much difference unless you go with bigger dia. rotors, good brake pads make a big difference.
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
1998 Dodge Ram SS/T
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
