vibrations suck!
Old Jul 19, 2001 | 02:03 PM
PAformula's Avatar
vibrations suck!
I've discussing my high speed vibration alot lately here and the vibration is nor apperent around 50+ mph. What is the deal? How do you check for a bent axle? I just put 4 new tires on ans everything seems tight up front. could the steering box or pitman arm be bad & causing the vibration?
thanks!!
1989 FIREBIRD FORMULA 350
K&N, ACCEL CAP & ROTOR,
FLOWMASTER AMERICAN
THUNDER CAT-BACK
http://members.fbody.com/tomahawk350/
Old Jul 19, 2001 | 02:51 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Have you tried having the driveshaft balanced? That is a common problem with our cars. Mine included. Fixed my vibration that I couldn't trace to the front or rear wheels. I would think a bent axle would be checked by running car on jack stands and looking for wheel wobble.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 19, 2001 | 02:58 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I also suggest having the driveshaft balanced. I had similar problems and the driveshaft was the main reason. You might want to have your new tires rebalanced too. I've had bad balance jobs on brand new tires before.
Old Jul 21, 2001 | 12:03 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I went though the same problem, it turned out my drive shaft was bent, So I put a new steel one in and it was back to normal, I then replaced it with a aluminum one and what a diffrence that made.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jul 23, 2001 | 07:30 AM
PAformula's Avatar
I heard that I can get an aluminum ds made for my car for about $100. I this is true I'm going to just do that.
FLOWMASTER AMERICAN
THUNDER CAT-BACK
Pac J
May 17, 2020 10:44 AM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
