brakes from drum to disc
Old Jul 21, 2001 | 09:24 PM
beam454's Avatar
I have a 83 camaro that had a v6 and drum rears. I dropped in a built 350, and changed rear ends to a 86 Iroc-z with discs. What problems wii i run into doing this?
Old Jul 23, 2001 | 08:31 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You may have to change out the proportioning valve or the master cylinder, but I don't know exactly how the system will perform. Look into the temporary 1LE upgrade section, under the Guldstrand bracket discussion. All the prop valve and M/C part numbers are listed there with their applications. Hope this helps.
Old Jul 23, 2001 | 11:34 AM
Fastcamaro87's Avatar
u will need to change, the master cylinder proportioning valve, all e-brake cables, and the rear brake hose.
87 IROC-z 305 TPI 5spd 10-bolt 3.73 posi ,8.8 Accel wires , bosch platinum +4 plugs,gutted air box ram air, K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
dbrochard
Oct 3, 2015 12:43 PM
64Chief
Sep 12, 2015 08:05 AM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
