Front brakes locking on and smoking hot.
Old Jul 20, 2001 | 08:16 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
On my 1986 Iroc I had the right front brake lock on creating tons of smoke and stoppint me. I then changed the rotor, caliper, pads, on that side as well I changed the pads on the drivers side. I went for less than two miles and the drivers side brake locked up smoking like crazy again. Any Ideas what could be causing this problem.
Old Jul 21, 2001 | 01:38 PM
Omar's Avatar
Maybe you should try changing the brake line going to that side. Then after that, the master cylinder.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 21, 2001 | 05:31 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Simplest and best first: Change both front flexibles (internal collapse causes this). You must bleed through plenty of brake fluid as well since the old stuff will have well and truly boiled! Then as the gentleman said before, change the master cylinder.
Old Jul 21, 2001 | 09:25 PM
Blackroc86's Avatar
Car: 1986 Iroc
Thanks for the advice Omar and Andy. I changed the flexible lines on both sides and bled them thoroughly. That seems to have fixed it and my braking is now way better than it has been since I have owned the car.
Old Jul 23, 2001 | 12:36 PM
ATOMonkey's Avatar
Does it pull at all now? My old car does the same thing. Let me know how it turns out.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 23, 2001 | 01:58 PM
Blackroc86's Avatar
Car: 1986 Iroc
Thanks again. The car brakes perfectly straight now and like I said before the braking has improved tremendously.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
