can u say CLUNK?
can u say CLUNK?
My car will ocasionally make a clunk sound when I brake or go around corners, and put stress on the suspension...WHat do I need to check?
Zak
1991 Z28, Black ext. Grey leather interior.
-Engine/exahust Mods:
-=MSD 6A Ignition/MSD Blaster Coil
-=Flowmaster/no cat
-=Headers
-=Air foil.
-=Superchip.
-Drivetrain:
-=2k Stall
-=1LE Aluminum Driveshaft
-=Customer Shift Kit.
-Free Mods:
-=TB Coolant
-=Modified air box
-=Removed Smog Pump (shorter belt).
-==Best Motor E.T. 13.59@102==-
Zak
-=Flowmaster/no cat
-=Headers
-=Air foil.
-=Superchip.
-Drivetrain:
-=2k Stall
-Free Mods:
-=TB Coolant
-=Modified air box
Where is the sound coming from? If it is the front you might want to check the ball joints. Mine was clunking and it was the left ball joint. The joint was toast it would move around in the housing.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Been thru all that... Last year I replaced ALL steering and suspension components (because they needed it), but when all was said and done, I still had that "clunk" you speak of. This past Friday I replaced my brake calipers and problem appears to be solved. No more clunks. Calipers are cheap - $13 each (unloaded) at NAPA...
KAM
KAM
Ok, what if the clunk sounds like it is coming from somewhere around the right rear passenger seat under the car. Seems to happen when there is a combo of a turn and a bump (like when turning onto another street that doesn't transition smooth). I've only recently started noticing, so haven't had a chance to start looking on my own yet. Thanks
Car: '91 Z28
Axle/Gears: 323's
MikeS;
first check out the rear components - shocks, trailing arms, torque arm, etc. to make sure you're all nice-n-tight in there. Also, check the "play" in the rear, trying to push/pull the wheels from the axle... it will most likely be a busted shock you're hearing. A sure sign of it is if the bushings on the end links back there are all chewed up, but it would have to have been busted for some time for it to do that... disc or drum brakes?
KAM
KAM
Now that I listen to it some more, I'd say it sounds like it is actually a little more forward than the rear end. More like under the passenger side seats. I got the car only a few weeks ago, but think the shocks are fairly new. I can't put it up on ramps right now, cause all my ramps and jackstands are under my other car at the moment. I could see it being something with the torque arm, possibly lose at the rear end, although that is farther back than the sound seems to come from. Its wierd. My sound seems to come from an area of the car where there are no moving parts. Go figure. Rear drums by the way.
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Have you checked your transmission mount. That is generally makes that noise and is a VERY common problem. Hard to tell if its bad without jacking up the torque arm a little to take weight off of mount.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
** Added so far **
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
Well it's none of those things....it's when I brake...I know what a broken or loose transmission mount sounds like...and this sounds like 2 piece's of metal rubbing against each other to make a CLUNK. and when I turn into some places that have a high curve....it makes that noise 2.....
Zak
Zak
luvofjah
Sep 26, 2015 08:28 PM
Ragtop Man
Sep 12, 2015 12:23 AM
