Tighten sloppy steering?
Old Jul 28, 2001 | 12:26 PM
colincamaro's Avatar
I have a 89 rs 305 a/t, the steering is a little sloppy. I thought this was adjustable, if so , how is it done?
89 RS 305 TBI/Hooker catback
Old Jul 28, 2001 | 02:22 PM
82camaro's Avatar
Car: 82 camaro SC
If the steering box is loose, sure you can tighted it up a little. But, the suspension has alot of other parts that could cause the same problem. Have the front suspension check out to see if any parts need replaced. Then get it aligned. Then adjust the steering box if needed.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Ed1LE
Sep 30, 2018 09:14 AM
gord327
Oct 3, 2015 01:25 PM
sjorgens
Oct 1, 2015 07:54 PM
FormulaEngland
Sep 30, 2015 01:50 PM
Night rider327
Sep 25, 2015 04:19 AM
