Why this noise is going away whenI press the brakes?
Old Jun 4, 2001 | 07:33 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
My front brakes squeal when the car is moving but when I hit the brakes there is no noise.
It happened after about 3 weeks from a brake replacement.
Weird. What could it be?
PS. One month old Premium pads, brand new calipers/installation kit
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, All free mods,
Old Jun 4, 2001 | 03:55 PM
sleeper's Avatar
Did you remember the clips that hold the pads to the calipers? If so... did you apply anti-squeal sauce to the back of the pads?
Check to make sure the squeal bar on the pad is not misaligned (ie. dropped when you were changing it).
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
Old Jun 4, 2001 | 08:15 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
This may seem like a dumb question, but did you have the rotors turned (resurfaced)? If not then the pads will wear down fast into the grooves on the rotors. Then the warning fingers will squeal not too long after a new set of pads.
Just a thought.
Old Jun 5, 2001 | 06:49 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I have turn the rotters and their surface is flat.
I can only think of one thing. I have used old brake shims.
I am going to replace those soon.
Thanks for replies guys.
Old Jun 10, 2001 | 09:46 PM
rode51's Avatar
Car: 84 Camaro (weather permitting)
Engine: 434
Usually thats the low pad sensor, but since you've got new pads I gotta wonder if you didn't buy el cheapos, and they're wore back down to the sensors again.
Just wondering. Thought you might want to take a look
50 year old kid in an 537hp 415 CID 84 Camaro
Real men aren't bottle fed
Old Jun 17, 2001 | 06:19 PM
Marc 85Z28's Avatar
Either they did a $hitty job machining the rotors or they didn't lube the caliper slides.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, built 700r4 w/Darrell Young 2400 stall TC, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Aug 1, 2001 | 07:02 PM
Blue_Meanie86SC's Avatar
I'm havin the same problem, just popped up on me after about 12 months of normal driving. I've searched the threads here and I think it might be the bearings, I'm gonna take a look at it soon and see what needs to be done. I plan on checking the calipers too to make sure they're retracting properly.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
