Suspension troubles
Old Aug 8, 2001 | 01:49 PM
duke_mushroom's Avatar
Suspension troubles
I bought my 91 Camaro RSalmost 3 years ago. When I first got it I knew it was lower thatn most stock Camaro's. The thing is everywhere I go I scrape the front end. Driveways, speed bumps, anything. I have also broken part of the front air dam because of this. Now looking at other parts of the car I have found that the original owners did not replace anything on it. Some of the parts were so worn that they crumbled into dust in my hands. My question is this this, did any 91 RS's come with a suspension package that made them lower or is this just another thing I'm going to pay for because of the original owner? Also, where can I find OE suspension to get my car back up to ride height? Thanks.
Old Aug 8, 2001 | 02:50 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I don't have a classified ad or anything, but if you want stock '91 RS suspension, I'll sell you mine.
Old Aug 8, 2001 | 04:20 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
The reason you scrape everywhere is probably because your stock suspension is worn out. I used to scrape all over the place, but after I put new shocks and James lowering springs in it, I scrape a lot less, even though my car is a bit lower. There is less suspension travel and it doesnt sag when I hit a bump.
Old Aug 8, 2001 | 07:04 PM
That's what I had figured, but I just wanted to make sure. Thanks
mrbird
Oct 20, 2015 03:43 AM
LT1Formula
Oct 8, 2015 08:34 PM
