Rear end/wheels are off center???
The wheel on the passangers side stickes out about and inch and a half farther than the wheel on the left. I know they are in set the same. They came as a set, but I did have a pretty back smack against a curb ones. Had to replace the axle, left rotor and both wheels. What else could cause this. It's very visually noticable from the rear. Looks like the whole rearend needs to be shoved over to the left 2 inches???
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
ALL IN ONE CAR!!!
Car: 91 Red Sled
Car: 4
Engine: 6
Transmission: 5
Yup, check the Panhard bar.... it's toast
ICON Motorsports
ICON Motorsports
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My car is like that also. Panhard bar disconnected and the rear end hangs free and it sits over to the passenger side. It's really noticable if you have rims that stick out too far. You may have bent parts from hitting the curb but all third gens are like that. Just some are more noticable than others.
The entire drivetrain is actually sitting towards the passenger side. Draw a line up from the center of the engine and it won't come up to the center of the hood. It's all moved over to allow room for the steering shaft. Even my big block sitting on solid motor mounts sits slightly on the passenger side.
Now since the engine is already moved over, so is the tranny. The differential pinion isn't offset very much so to line it up, the diff sits slightly to the passenger side also.
I'd check for any bent parts first. I have an adjustable panhard bar and when I tried to center the diff, everything went into compression when I tryed to force it into the center. I just left the panhard bar off, shook the car around to get everything moving free and reconnected the panhard bar. No parts are under any stress now.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
