Anyone know about front-end/steering parts????URGENT ?s
Old Aug 13, 2001 | 04:29 PM
squirrelybird's Avatar
Problem:My car gets the bad shakes 60mph plus.
so... today I took it to get the tires rebalanced and they were fine. Then the guy showed me that when the steering wheel is held straight (on a lift) you can wobble the front wheels around. He said I could have a problem with a steering part. The real problem is that I leave for a 2 hour drive to college on saturday 8/18 so I need this fixed A.S.A.P!!! How do I diagnose it? Can I fix it? How much $$ should I expect to dish out???
Old Aug 13, 2001 | 04:52 PM
matthew's Avatar
I'm no expert but I say check all the bushing and the tie rod ends for play. If you are in a big emergency, have a shop fix it for you, at least you know it will get done right, and will save you the hastle in case something goes wrong.
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Aug 13, 2001 | 05:10 PM
Bjase's Avatar
Car: 88 IROC
I spent under $200 for every moving part in the steering, plus an alignment. Did all the labor myself in one day.
If you're not a mechanic at heart, it would probably be best to take it to a shop... a big name one, so you can get any warranty issues fixed at your new locale.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Aug 13, 2001 | 05:30 PM
well i checked....seems everything moves below the balljoints and everything above stays still (when I jiggle side to side). Does that mean the ball joints are bad? or maybe need to be tightened? Where can I buy? How much $? Can I fix? Thanks.
Old Aug 13, 2001 | 06:13 PM
Sorry--not balljoints...I think I meant balljoint studs??(what shop manual calls it I think) It is where the inner tie rods connect to the relay rod/pitman arm and the idler arm on the passenger side.
Old Aug 13, 2001 | 10:01 PM
Guys..I need all answers by tonight. This really is urgent! Please help!
Old Aug 13, 2001 | 11:25 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Where's the fire??
If you're in that big of a hurry, take it to a shop and have it fixed:; they'll probably charge you more for a rush job. If you can't fit that in, set the cruise at 55 and leave an hour early...fix it later. In my opinion, I'd wait and replace everything later with quality poly parts and do it right while you're in there. If it's just the ball joints, you STILL have to pull the control arms off to have them pressed out, so why not do the lower control arm bushings too? I don't think you can "tighten" a ball joint..once the go, they're gone. They're about $15 each at any parts store (buy Moog or TRW), and unless you have a press in your dorm room, no, you can't do it. Good luck man..
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
