rear-end swap q's
rear-end swap q's
I am curious to know..... I have a drum brake 2.73 rear end....If i purchased an iroc disc brake rear end....could this swap be done in the driveway? How difficult of a swap is it for someone with mechanic experience?
Make sure you get all of the bracketing for the calipers, you need to master cylinder and proportioning valve. Be prepared for this to take more than one day as all of the bolts and nuts have fused together over the years. You'll need lots of room to drop the rear if you don't use spring compressors. Do a search, because this is a very common swap.
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
Did this same swap in my driveway. Took about one day. Hardest part of the whole thing is fighting with the bolts. If you've never had the backend a part there bound to be very tight. I recommend u find a good size pipe to put on the end of your rachet or breaker bar.
Good Luck
P.S Be careful with those brake lines.
406SBC
-DART SPORTSMAN 2 HEADS
-RPM INTAKE
-750 SPEED DEMON MECH SEC. CARB
-HEDMAN HEADERS
-COMP CAM EX .507/.510
-1.6 roller rockers
-th350 tranny
-posi rear disc
Good Luck
406SBC
-RPM INTAKE
-HEDMAN HEADERS
-1.6 roller rockers
-th350 tranny
-posi rear disc
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, the rear swap is cake; the hardest part is getting the brakes set up. I put a 3.73/posi/disc axle into my car; I fought with a bad "rebuilt" master cylinder for a week. Another "rebuilt" m/c fixed the problem, and gave me rear brakes. I also rebuilt one caliper, replaced the other, replaced the rear wheel bearings & seals, painted it with POR-15, etc...
But an axle-for-axle swap is cake.
You also don't -have- to change the master cylinder. Apeiron dug up a GM notice for us (thanks!!) that shows proof that the disk/drum master cylinder -will- work on a 4-wheel-disc system. Here's the message link: https://www.thirdgen.org/messgboard/...ML/001977.html
Hey! Can we get that message put into the FAQ?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Hello, Michael
Aug 20, 2015 03:19 PM
