Steering question... pls help....
Old Aug 16, 2001 | 05:38 PM
skheckert610's Avatar
I've got an 84 Z-28 with a steering problem. It has tilt steering and if you grab the top of the steering wheel you can move it all around( Like when you're using the tilt but you don't have to actuate the arm ). I've taken it in to the dealer once ( years ago ) and they told me they had to tighten four bolts up. Does anyone happen to know where those bolts are??? I'd like to know before i start ripping stuff apart.... Thank you
Old Aug 16, 2001 | 05:46 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
If you are not a mechanic I don't recommend you do this yourself. You need to pull the steering wheel and dig rather deep into your column. If you lived down here I'd do it for free. I would bring it to a repair shop and let them do it. The four bolts have a special head on them, you would need an inverted torx socket (not sure what size, maybe a 4) with a 1/4" ratchet w/ extension. Even this way you would only get to three of the 4. If it a persistant promblem, like it loosens up again in a couple of days, you would need a new or junk yard column.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Old Aug 16, 2001 | 07:25 PM
Well.... I'm an aircraft mechanic. I don't really work on cars a whole lot. Does this job just require a good sense of mechanical inclination or is this a job that should be left for an auto mech? My vagueness in the question is because my Z is stored at my parents place which is a ways from where I live so I can't just go out and take a look at it. I'm making provisions to get it up here but that's not for a few months and was wondering if I could do this myself or not. Would it help to Loctite the bolts in place??? to keep them from backing off again??? Thank you for replying
Old Aug 16, 2001 | 10:51 PM
82camaro's Avatar
Car: 82 camaro SC
With the right tools and some mechanical inclination you shouldn't have much trouble.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Night rider327
Sep 25, 2015 04:19 AM
