3rd Gen upper strut mounts
Old Oct 2, 2010 | 09:40 PM
Larry Woodfin's Avatar
Does someone build a solid/race style upper strut mount for the 3rd gen cars?
Or is the OE mount acceptable?
Old Oct 3, 2010 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 3rd Gen upper strut mounts
Here's one version (a search will turn up more):
http://www.spohn.net/shop/1982-1992-...ut-Mounts.html
For daily cruising the OE version would be acceptable.
JamesC
Old Oct 3, 2010 | 09:19 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
also umi and j&m make virtually the same spherical strut mount.. i have umi adjustable caster plates and my car is lowered...... made a big difference.... if your not into handling or cornering and its just a daily driver then the stock type mounts will do fine... but if you are a corner craver then i suggest on getting the upgraded units....
Old Oct 3, 2010 | 09:57 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I can vouch for the spohn ones I bought a set off a member on here. I haven't installed them yet but there a ton bigger and beefier than the OEM ones.
I'm in the process of changing my car over to a street/strip type so figured upgraded mounts would be nice since I'll be pulling apart the front end anyways for a new K-member, brakes, struts, springs... etc.
Old Oct 3, 2010 | 10:05 AM
JamesC's Avatar
Since you're swapping in after market mounts, you might consider a STB at some point.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
