Grant wheel horn button >:(
Old Aug 23, 2001 | 08:35 PM
PhantomChamp's Avatar
I decided to change wheels because the horn buttons in my original airbag wheel broke and were hard to replace. So I put on a Grant wheel and can't get it's horn button to work.
I know the horn works on the car because I touched the wire to the center bolt.
The adapter kit came with a metal sticker type thing, but I can't figure out where it goes,or if that's even the problem.
Who else has done this?
Thanx!
Old Aug 23, 2001 | 10:52 PM
Project86Iroc's Avatar
The sticker mounts in the center of the steering wheel. the horn uses the wheel as a ground to activate the relay and sound your horn. without that sticker, there is no ground, so no activation. Here is the real fun. If its a challenger series with that damned 3 prong mounting, now you have to pop the button of and try and get it to lock back on the disc. Mike
"Experience life, Don't use it" Julie (petrick) Fink
Old Aug 24, 2001 | 11:43 AM
Ok, I fixed it! It is the challenger series, and boy did I scratch the damn thing up!
Thank you, mike!
Old Aug 24, 2001 | 07:36 PM
Any time, any time brother. I Had a different problem with my grant. I installed the horn and left for New York the next day. well of course, I locked the doors and rolled the windows up. I got a screaming phone call about two days later asking where my keys where. The horn button popped off, and the horn grounded itself, so the horn was blowing for two days straight(THANK YOU DURALAST BATTERIES!!) It finally killed itself that night. If you have any other questions, lemme kno
Mike
Old Dec 29, 2001 | 03:38 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
im having the same problem, but don't know how to fix it. i put the wire with the button end into the horn housing (white thing) and it doesn't work with the button. im goin to try to touch the wire that is connected to the disc to the shaft and see if the horn works.
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
luvofjah
Sep 3, 2015 07:08 PM
