Tips on heating springs...
Old Aug 24, 2001 | 04:32 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
all you do is lift the car. Heat up one coil. And then lower the car toe the height that you want right? any other things I need to know? thanks... OH yea I'm not doing this to my car.
Chris
91 RS 305 TBI
Eternal Rev
I am sad my car is hurt...
Old Aug 24, 2001 | 06:30 PM
Bjase's Avatar
Car: 88 IROC
You shouldn't do it to ANY car. You're better off to cut the springs, but this will make the ride firmer. The best bet is to bite the bullet and buy a proper set of lowering springs.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Aug 24, 2001 | 07:39 PM
82camaro's Avatar
Car: 82 camaro SC
Lowering springs aren't that expensive anymore.
http://64.49.196.9/product.asp?3=2136
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 24, 2001 | 09:45 PM
REVLIMIT's Avatar
Engine: Built L98
To late I did it to my friends car already. Slammed it to the ground. Nah not that much anyways. Just dropped it like 2" the ride is still smooth to my suprize. Andt he car looks alot nicer. Oh yea and hes buy coil overs soon also so he doesnt care about his stock springs.
Chris
91 RS 305 TBI
Eternal Rev
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Thaney9
Oct 15, 2015 06:37 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
