Poly suspension kits
Old Aug 31, 2001 | 10:00 PM
98_1LE's Avatar
I would like to rebuild the front suspension on the Formula with poly bushings, including the subframe/body mounts. What kits are available, and what is included with them? I would also like some feedback on how this affects ride/handling.
-Chuck
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Sep 1, 2001 | 02:54 PM
nicmike85's Avatar
Most companies offer complete kits. This should include bushings for: lower a arms, sway bar and end links, trailing arms, center link, rear sway bar and end links. Thats the basic. You could also get motor mounts and a trany mount. When buying for a full frame car you get body mounts. You also want to get strut tower mounts if possible. This may not be available from a poly company.
Old Sep 1, 2001 | 03:17 PM
98_1LE's Avatar
Thanks nicmike85, I guess I need to research the different kits offered by different manufacturers. I am open to suggestions.
Old Sep 1, 2001 | 09:32 PM
nicmike85's Avatar
I have heard the polygraphite kits are better than the polyurathane. They are supposed to be quieter. I have run polyurathane motor and trans mounts and I am quite satisfied with them. You can feel more engine and drivetrain vibrations but I like to feel a performance car. At first it felt strange but now I can't even tell. Guess I got used to it.
Old Sep 1, 2001 | 10:32 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
just did the front end with PST's kit and it made a full 100% improvement in handling. I am really amazed day to day at how much tighter the car handles. and it also seems that when I go over bumps and such now the car actually absorbs them better and doesent reverberate the shock through the body of the car. I have driven 90's Vettes that did not handle half this well.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts, PST front end poly stuff,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system. Ported plenum, intake and heads with 1.94I valves.
Planning: Heddman 1-5/8 longtubes, NOS 150 plate, replace the "peanut"! and Eibach Sportlines.
check it out at:
http://www.geocities.com/transam617
J-money
Jan 4, 2019 09:45 AM
luvofjah
Sep 10, 2015 10:41 AM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
