Need new brake lines
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have brake proportioning problems and I am going to replace the lines and the MC to see if I can fix it. just so you know, EVERYTHING else has been replaced so these two things are all that is left to do to have a completely new system.
I was just wondering where I get brake lines and if there is some aftermarket performance version that I should consider like All-steel lines or something
thanks for the help.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts, PST front end poly stuff,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system. Ported plenum, intake and heads with 1.94I valves.
Planning: Heddman 1-5/8 longtubes, NOS 150 plate, replace the "peanut"! and Eibach Sportlines.
check it out at:
http://www.geocities.com/transam617
SSM SFCs, Bilsteins
check it out at:
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
there is a company that does sell direct replacement lines, pre-bent, with the protective coil around it. The URL is at work, so I can post it when I get in later.
As for the flex lines, Stainless Steel Braided. Earl's has them, as does Russell. Order them thru Stropes so that you get the complete kit. Some only come with 3 hoses, instead of 5.
Car: 87 T/A
Engine: TPI 350 ci
The company is calledInLine Tube for all your pre-bent tubing.
Also www.finelinesinc.com sell pre-bent lines. I used them for all my hard lines and the fit was real good.
