Good alignment specs?
Old Aug 31, 2001 | 12:48 PM
mcconahay37's Avatar
DOes anyone have some good alignment specs that can improve handling without wearing too bad? I just got my struts replaced and an alignment done, and it understeers really bad now. I think an alignment could help this. I have 215/65/15 tires. Thanks.
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Old Aug 31, 2001 | 01:01 PM
82camaro's Avatar
Car: 82 camaro SC
-.5 camber
+4.5-5.0 caster
+1/16 toe
Is a good place to start. Alot depends on how hard you drive.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Aug 31, 2001 | 02:58 PM
JPrevost's Avatar
Car: 91 Red Sled
Either the FAQ or the tech articles have a post on good alignment specs. If you lower the car much your caster is probably going to need to be maxed out and that's the best you can do with stock equipment. Your tread is small so I don't know if an alignment will really help a whole lot with the understeer problem but it might.
, Jon (350 TBI!)
91 Red My website
Old Sep 2, 2001 | 10:10 PM
AntiVTEC's Avatar
What about a car that is driven HARD, but not at the track like laguna seca? BTW, the car is dropped with eibach sportlines.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Amillionoh7
May 24, 2020 08:01 AM
80s Poncho
Aug 19, 2015 06:45 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
