draining brake system
Old Sep 2, 2001 | 11:52 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
If I drain the brakes below the level of the Master cylinder will that neccesitate some kind of special proceedure to fill the system back up. Or can I just fill the MC again and bleed normaly. I have heard of "bench bleeding" the master cylinder but I dont know what it is or how to do it.
thanks for any help.
Old Sep 3, 2001 | 07:08 AM
ede's Avatar
ede
i take it you're removing the MC? if so yes you'll have to bleed it and maybe the entire system. to bench bleed the MC you clamp it in a vice and attach a rubber hose with nut to the brake line ports and the force the hose shut and pump the MC up then releaase the hoses to let air out the force closed again and repete
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 3, 2001 | 09:21 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
actually I am replacing lines but I figured that I should eliminate all slop in the pedal so I want to get all the brake fluid replaced.
I am not sure about your explination. do I pump fluid into the MC bacwards through the brake ports and then where will the air come out?
Old Sep 4, 2001 | 09:57 AM
87tpi420's Avatar
i always heard you just loop a hose into the master cylinder and put some fluid in it and push the piston in. this way the fluid recirculates and the air is worked out of the mc
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Frozer!!!
Jan 19, 2024 04:55 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
zayne0
Aug 24, 2015 07:22 PM
