Sticking brake??
Old Sep 5, 2001 | 09:00 AM
91Firecrow305TBI's Avatar
Sticking brake??
I just bought an 88 Camaro (base) for a friend, and it pulls to the left if you let go of the wheel, pulls to the right when you brake, and slows down fast if you get off of the gas, and has no idle. I thought maybe a caliper was sticking, but my gielfriend thinks one of the sensors is bad. Either way we will replace both of the calipers or both of the sensors, Any ideas??
Thanks,
Clint
Flowmaster 80 series muffler
no Air/Cat, straight pipe
no smog pump/pulley
K&N Open Element cleaner
Ultimate TBI Mods
1" TBI Spacer .25" Injector Spacer
Homemade Subframe Connectors
GM Wonderbar
lead pedal foot . See my project rocket turtle @
http://oursportscars.homestead.com/firebird.html
Member of Tidewater Trans Am Club
www.ttac.net
Old Sep 5, 2001 | 10:01 PM
nicmike85's Avatar
Sounds like you need an alighnment for the pull. Check the pads for uneven wear. It probably needs the right caliper or at least rebuild it. What sensors are you talking about?
Old Sep 5, 2001 | 10:53 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Did you replace the hoses and properly bleed the brakes?
Kat
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
