Question on Bilsteins
Old Sep 5, 2001 | 04:43 AM
Steve's Avatar
Car: 91 Z28
I have been looking at the Bilsteins rear shocks. I would like to know the real difference between the regular Bilstein shocks and their Sport version.
Thanks,
Steve
Old Sep 5, 2001 | 09:44 PM
nicmike85's Avatar
You need to call bilstien. It is a difference in valving more then likely. Could also be a linear vs. progresive differance.
Old Sep 5, 2001 | 10:49 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i would also like to know what's the difference. I looked up the price at autozone on some Bilstein's and they have 2 types. 1 being the heavy duty setting and another being a sport setting. both being the same price, does anyone the difference? Also are the Bilstein's any better than the KYB's?
88' IROC-Z, 350 TPI, 700-R4
[This message has been edited by mystikkal_69 (edited September 05, 2001).]
Old Sep 6, 2001 | 03:55 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The Sports are 1" shorter then stock and HDs. The valving is the same as the HD. They recommend them for cars with lowering springs because at full suspension extension, the shorter lowering springs will want to fall out with a stock length shock. Since the Sports are 1" shorter, they compensate for the 1" shorter lowering springs.
And they are wayyy better the KYBs. I know, I've had both.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
[This message has been edited by Justins86bird (edited September 06, 2001).]
Old Sep 6, 2001 | 12:25 PM
Car: 1988 IROC-Z
thanks for the info Justins86bird.
Old Sep 6, 2001 | 01:08 PM
Tas's Avatar
Tas
http://www.ws6.com/f-bodygp.htm
Old Sep 9, 2001 | 04:49 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The lowering springs will "fall out" of the Eibach HD's? I guess I'd better tie a rope to them so I don't lose them. Actually, I have Eibach Pro-Kit springs with Bilstein HD shocks. I just swapped rear ends again and installed the shocks prior to installing the springs. FYI, if they can "fall out" I should have been able to get them in with the shocks at the max stroke. Nope. I had to pull the shocks loose again to install the springs.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
