how big can you go?
Old Sep 9, 2001 | 07:38 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
how big can you go?
This next summer i am gonna "rebuild" my car. How big of tires have people put in the rear of the car. and could you give me specs of the front and rear rims (backspacing and offset and all that crap)
and has anybody mini tubbed their car? I am considering on doing this, can anybody give me pointers on the procedure.
Old Sep 9, 2001 | 08:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on what kind of tires you plan on using.
My race car currently has 10 x 15 rims with a 5.5 backspace. You can go a little more with drum brakes but not much. Maybe 6" backspace max.
Height wise I currently have 28" tall tires and feel I can get 29 or 29.9 inside the wheels wells. 30" may require a bit of metal fabrication. When I go to 4.56 gears I'll have to fit a taller tire into the wheel wells so I'll know what needs to be shaped at that time.
Width, I currently have a 9" slick but feel I can go to an 11" before I need to start moving metal around. Those are drag tire measurements. The width is measured across the tread. DOT tires are measured across the section. DOT tire should be 11.5-12.5 max. Other will know for sure. I ran a ET Street 26 x 10.5 x 15 with lots of room.
As for mini-tubing there's very little you can remove. The passenger side spare tire dimple can be pounded out for a bit more room on that side. The fuel filler neck "may" be in the way on the driver side. The inside fender can't really be mini-tubed because of how the springs are positioned. If anything, you may gain 1" without repositioning the springs.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Sep 10, 2001 | 01:48 PM
Car: 1985 Z-28
Engine: a big one
I was thinking that the springs would be a problem. What if I were to go with a different suspension setup?
like a independent rear suspension like a old vette or a heid's rear end. Is there even enough frame metal in the back to do something like that?
Old Sep 10, 2001 | 09:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You may have to backhalf it to do something like that. There is no real rear frame on a third gen. The top of the shocks only bolt to sheetmetal.
Even to minitub the car, you would probably have to backhalf the car. The springs sit under what little rear frame there is already so to move them over, you need to move the frame rails in.
Old Sep 10, 2001 | 11:05 PM
Car: 1985 Z-28
Engine: a big one
I think that putting in irs in a camaro would be cool. the rear ends are going for less than 1k on ebay. to me it seems that there is only a couple of mounting points to worry about, and you could probably incorperate the mounts with the spring mounts. i wonder if it would actually work.
Old Sep 27, 2004 | 08:38 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Its been done. Not mine but look at the IRS... pic's
http://s89724942.onlinehome.us/image...IRS%20rearend/
BTW Im in the middle of Mini tubbing mine. One thing you have to do to stuff a larger tire back there is remove the bumpstop.
Right now I have a 27x11.5x15 under there and its hitting the bumpstop. but sits flush with the rolled outer lip of the fender.
stock spring and shock locations right now also.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
