lowering springs?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: lowering springs?
Sportlines are a 2" drop - you'd want the ProKit from Eibach which is a 1" drop.
You'll probably need an adjustable panhard bar as well - lowering the car makes the rear end not sit evenly under the car left to right and an adj panhard bar will correct this.
Car: 87 GTA
Even on a stock spring, stock wheel & tire and good shocks, an Adjustable Panhard Bar can be a good thing.
On my 87 GTA, the rear axle was offset to the drivers side, by almost a full inch. So I HAD to put one on to fit my 315s.
Thornburg
Sep 12, 2015 10:11 AM
