Inside edge of left front tire wearing out fast
Old Sep 11, 2001 | 09:03 PM
GTA88's Avatar
I noticed the above happenning. Could that be caused by a worn idler arm? I just changed my idler arm, and am wondering if I should get an alignment. Wondering if the new idler arm has fixed the inner edge wear problem. It's just the inside 1 inch of tread on that tire. The tread is worn off, down to smooth rubber there. Thanks
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Sep 11, 2001 | 09:08 PM
nicmike85's Avatar
That would be because of excessive camber. Of course alot of camber is needed if you drive hard.
Old Sep 12, 2001 | 08:33 AM
82camaro's Avatar
Car: 82 camaro SC
Excessive NEGATIVE camber is what can cause that. Usually an idler arm is going to affect the toe setting of the alignment. Which will affect both tires in the same manner. Could also be a bad tire. An alignment is all you can do, assuming the rest of the suspension is OK.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 12, 2001 | 08:52 AM
88 Camaro SC's Avatar
Car: 99 Trans Am
Yep, gotta be the alignment. I had the EXACT same problem, only it was both front tires. Turned out that either my toe or camber was a 2.3 when it should have been between .2 and -.2 Wow, big difference huh?
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Custom Ram Air
  • 180* Stat
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.com
Old Sep 12, 2001 | 04:59 PM
GTA88's Avatar
Thanks for the replies, guys. I am going to get it aligned soon.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
antares57
Aug 6, 2015 07:47 AM
