About to lower car... but front higher than rear
Old Sep 9, 2001 | 07:22 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
I installed new stock shocks and struts about 2 years ago. I have 235/55/16 on the IROC which raised the car about half an inch. I've decided to try and lower. I'm looking at Hotchkis, going through posts and doing some reasearch. Looking at the car... i think the rear sits maybe 1/4" lower than the front. I've been reading where the front is dropping 1" while the rear is dropping 1.5"??? Should i try the Kotchkis kit for $230?
86 305 TPI
700R4
3:42 axle
4 wheel disc
-Summit cam .442" lift
-Summit chain/roller
-Summit tranny cooler
-WORLD S/R Torquer 305 heads w/ LT1 springs
-High pressure oil pump
-Hypertech Airfoil
-SLP 1 5/8" headers
-CatCo cat.
-Flowmaster 80 series c/b
-Taylor Spiro-Pro 8mm
-Bosch Plat. plugs "hot"
-Indexed plugs
-K&N Air filters
-Trans-Go shift kit
-Removed AIR
-180 Thermostat
-T/B coolant Bypass
-All sensors replaced
-Custom Ram-Air
-Poly motor mounts
soon...
125 shot, slp runners, perf. chip, ported plenum
Old Sep 9, 2001 | 11:06 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Well, its hard to say. If you rear is lower right now, it might be because the springs are sagging or your missing the rubber isolators (or have a really big speaker box in the back ). I replaced my WS6 springs with the Hotchkis springs. The front was about 1" and the rear was about a 1.5" drop, but even with that, the front is still .5" lower then the back.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
Old Sep 10, 2001 | 12:26 AM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
I called summit, they recommended the eibach sport line kit. 1.6 in front, 1.3 in the rear. none in stock until the end of the month. where else can i get them?
he said hotchkis only lowers 1 in front 1 in rear, i'm looking for a slightly lower stance.
Old Sep 10, 2001 | 03:28 PM
82camaro's Avatar
Car: 82 camaro SC
The advertised drop is from original height, not your current height.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 10, 2001 | 09:50 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
thanks for the information, i think i could figure that one out on my own.
Old Sep 10, 2001 | 10:21 PM
82camaro's Avatar
Car: 82 camaro SC
How should I know what you can and can't figure out? The back tends to sag the most, so using the current height(lower in the back than the front) is useless. Ignore your current height. A set of drop springs will give you a level car. If you don't want help and ideas, don't ask.
82camaro
Old Sep 11, 2001 | 09:35 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I purchased mine from www.tirerack.com. I just checked and they are back ordered also. Might want to compare prices if you have to wait anyway. Tirerack is $208 + s/h (my s/h was $16) - Summit is $230.
I have mine on for about 9 months now and love 'em. My rear was a little lower before installing the springs and the car is now level.
Old Sep 12, 2001 | 02:53 AM
Kandied91z's Avatar
spend the extra and go with eibach's if you want it really low go with the sportlines; remember that when they say it lowers the car it's from the factory height and not it's current height!
Old Sep 12, 2001 | 12:56 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
Hey Schultzy... thanks for checking. That's funny that you say the Sportlines are backordered at Tirerack... I bought the last pair the day before yesterday. After comparing prices, they were cheapest. Plus, they aren't some unheard of company that no one's dealt with before. Would an alignment be able to wait a week. Did it throw your camber off enough to notice and what do you think your initial drop was as soon as you set it down? Did it sag over time? I'm going home friday to pick up the car and do the springs. Of course I'll want to drive it back to school which is 100 miles.
86 305 TPI
700R4
3:42 axle
4 wheel disc
-Hypertech Airfoil
-SLP 1 5/8" headers
-CatCo cat.
-Indexed plugs
-K&N Air filters
-Trans-Go shift kit
-Removed AIR
-180 Thermostat
-T/B coolant Bypass
-Custom Ram-Air
-Poly motor mounts
soon...
Old Sep 12, 2001 | 09:33 PM
Car: 1989 GTA
No problem... glad that you were able to get them. You will definitely want to get an alignment but I put about 60 miles on mine before it was aligned. Apparently I needed some front end work done and the shop could not guarantee an alignment until it was accomplished. I had to wait a week for parts. I took it pretty easy during that week. I didn't really notice any problems before the alignment but I am sure that it was needed.
The initial drop was pretty close to advertised (a little over 1.5 inches in front and a little less than 1.5 in back) and it settled within a few days. The springs are pretty stout. I have not noticed any additional 'sag' or drop.
It accomplished my goals i.e to get rid of some of the extra space between the tire and fender without looking 'slammed' and to 'level' out the look as mentioned before. It also performs better in the twisties... you will be pleased.
I would like to see before and after pics when you are done to see how they look on an IROC.
[This message has been edited by Schultzy89GTA (edited September 12, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
