Question about shocks
Old Sep 4, 2001 | 02:42 PM
Steve's Avatar
Car: 91 Z28
I have a 91 Z28. It has the stock suspenion. My rear shocks are shot and i need to replace them. I would like to know what a good replacement would be for something comparable to the stock ones or better. I am kind of on a budget here. Any suggestions are appreciated.
On a side note. what is the easiest way to determine the size of the front/rear sway bar?
Thanks,
Steve
Old Sep 4, 2001 | 06:06 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
KYB's are pretty good shocks for what you have to give for them. Check them out in Summit.
Old Sep 4, 2001 | 07:30 PM
nicmike85's Avatar
Monroe shocks are pretty good and affordable. You can measure the sway bar with a wrench to get the size. If you don't have big wrenches then use a big adjustable and then measure the opening.
Old Sep 9, 2001 | 03:43 AM
Kandied91z's Avatar
if your on a budget get monroe; if you want the best then buy bilstein; although a lot of people seem to like kyb's. I've ridden in cars done with the 5 way kyb's and i use to have monroe before i threw them out for the bilsteins......best money i ever spent. can't say enough about them.
Old Sep 12, 2001 | 08:56 AM
88 Camaro SC's Avatar
Car: 99 Trans Am
I'd like to go with the KYB's too, but aren't they soggy since they're gas shocks & struts? Or would they still give a really firm ride?
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Custom Ram Air
  • 180* Stat
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.com
Old Sep 12, 2001 | 11:32 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i have kyb's and love them.
Old Sep 13, 2001 | 08:47 AM
Car: 99 Trans Am
What's with the KYBs? Are they good because of the firm performance-orientated ride? What is it?
Old Sep 13, 2001 | 05:30 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the KYB's and I like them fine.They're more firm than the factory shocks and struts but not harsh.Don't perform as well as Konis or Bilsteins, but for the money, I think they're hard to beat.I drive my car pretty hard most of the time and they've held up really well.I don't think you'll find a better all-around shock/strut than the KYB
for under $200/set.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
