Better handling with springs that lower a little
Old Sep 10, 2001 | 11:17 PM
Casey'91Z28's Avatar
What springs should I buy that will significantly improve my handling without lowering it too far?
1991 Z28 305 auto, homemade CAI, air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, PF brake pads, STB, SLP headers, 3" catco cat, spohn lca's, 4th gen 5 star wheels, 14.687@ 96.449 mph
Old Sep 11, 2001 | 12:46 AM
AntiVTEC's Avatar
Eibach pro-kit. Sportlines are a little stiffer and slightly lower, but handle much better. Make sure you get a good set of shocks too!
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 22, 2001 | 08:45 AM
Jason M 91Z's Avatar
If you really want it to handle, skip those progressive replacement lowering springs from edelbrock, eibach, and hotchkis. Call up Global West or Guldstrand, and get a real set of linear springs. I have GW S-9 street springs in mine (650 lb.). I can't believe how much better it handles, and how much more predictable the same bumps are every day as opposed to the stock springs hitting bumps differently all the time. You'll need a good set of struts with linear springs. I have KYB GR2's, and they're working well for now but I doubt they'll last long, then I'll go with Bilstein or Koni.
-Jason M. 1991 Camaro Z28
Old Sep 23, 2001 | 06:58 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Jason M 91Z
I have been looking to get some linear spring for a while because someone told me they are a little better for handling and autocross which I want to get into. And since it seems my springs are sagging I should get new ones. How are they on the street for eveyday use alittle harsher? How much did you pay?
Also Are they stock height or lower?
just looked there 1 inch drop. What do you have in the rear? s-39's?
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
[This message has been edited by john5.7 87Iroc (edited September 23, 2001).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
fasteddi
Sep 10, 2015 09:32 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
