Vibration from front end...
Old Sep 27, 2001 | 07:34 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Okay, when im going down the road, I get a fairly loud vibration from the front suspension. Sometimes it does it when i make left turns, sometimes on rightturns, and sometimes when i just go straight. This causes me to think its something with the steering. It varies with speed, not rpm, so I know its not from the motor. Its like if there is wieght on a certain tire it vibrates, because when I accelerate hard, it goes away, but when I brake, it gets louder. WTF is it? Every time someone rides in my car they say "What the heck is that noise?". I get paid tomorow and I would like to fix this.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Sep 27, 2001 | 03:26 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
BTT: Anyone? Even a good guess? I would really like to fix this.
1983 Firebird
TH700R4 Auto
Small Block 400
Old Sep 27, 2001 | 08:30 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
ya know.. mine does it on turns, is there like a weird like almost sliding on metal sound?
Time has come... i bought a nova.. so its time to sell the firebird.
http://cgi.ebay.com/ebaymotors/aw-cg...item=595764164
I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 28, 2001 | 08:44 AM
82camaro's Avatar
Car: 82 camaro SC
Bearings, maybe. Ever repacked them--should do it every 30000 miles or so. If they are making noise a repack won't help. Must be replaced.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 29, 2001 | 04:10 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I got my front end aligned at about 128,000 miles. All I wanted was a steering align which was supposed to be $55. When I went to pick my car up I had a $160 bill. They told me the 'strut to knuckle' bolts were loose and the wheels bearings were dry, so they re greased them and tightend the bolts. At first I thought okay, well I didnt ask for them to fix this, but its fixed now so its good. My steering is aligned good, but it started making a vibrating noise. I thought it was the tires, since I had driven with bad steering alignment and they had worn improperly. But the vibration has gotten worse since then. I want to know why they were even looking at me wheel bearings to align the steering. This requires thaking the discs off. They shouldnt take the discs off to align steering, right? I dont even think the wheels have to come off. My dad and I re-greased all 4 front wheel bearings when we got he car at 118,000 miles. Could they get dry this fast? Also, If my bearings are bad, should I complain to the shop or sue them or something? Can this mess up my spindles?
1983 Firebird
TH700R4 Auto
Small Block 400
customblackbird
Aug 15, 2021 10:16 PM
Americanmouse
Sep 7, 2015 12:10 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
db057
Aug 22, 2015 08:17 PM
spaigo
Aug 21, 2015 07:46 PM
