Rear drums dragging on one wheel
Old Sep 29, 2001 | 01:14 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
About a week ago, something must have seized the drivers side drum brake assy. It got real hot (read: smoking) on my way home and i took it apart. I jacked it up and ran it at around 20 mph and found that the drivers side tire would just sit and jerk a little, while the pass. side would be spinning freely (on a posi rear). I checked all the brake linkages, and replaced the ebrake cable when i found it was seized. The new cable seemed as though it would work properly, but something is still causing the brakes to drag. Is there something i missed that should be adjusted or could something else cause this problem.
thanks
jeff
EDIT:
Also, after i put the brakes back together after being apart and on stands for a few days, i had a loud clunking, fairly rhythmic, and strong enough to feel. It sounded ilke it was from the middle or front. Its not a transmission mount kind of clunk, because its speed-related and at regular intervals ~1 per second @ 25 mph.
any help on that one?
[This message has been edited by slickrock55 (edited September 29, 2001).]
Old Sep 30, 2001 | 08:51 AM
ede's Avatar
ede
i'd replace the springs and related hard wear. clean everything up and reassemble and see if the problem doesn't go away.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 11, 2012 | 09:55 AM
sonicwolf89's Avatar
Re: Rear drums dragging on one wheel
i have the same problem on the passenger drum.. it has all new hardware and cylinders. i almost couldnt get the drum on
Old Jul 21, 2012 | 09:39 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Silly question probably....did you recently lower the car?
After I had mine on stands with them under the rear (normal ride height), I discovered that my e-brake cable was on top of the TQ arm...every time I hit a decent bump, it activated my e-brakes a little...that's why I'm asking.
jaridjohn
Jul 8, 2024 03:49 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
