Gullstrand 1LE Brakets
Old Oct 1, 2001 | 12:46 PM
Matt_91RSTPI's Avatar
Does anyone have a picture of the Gullstrand brackets? I think I have a pair. I was comparing them to the stock GM anchor brakets though and the outermost bolt hole on each end of the Gullstrand braket seems to have the surface of one side machined down a bit. Is this correct? Does it affect how they mount to the spindle?
Thanks,
Matt
Old Oct 4, 2001 | 08:37 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have a set.. and thats how they are the area around the bolt holes is machined down. It does not really say in the install instructions which way they go. It should be easy to figure out though. If the caliper isnt inline with the rotor then you know its on the wrong way.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Oct 5, 2001 | 08:19 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The recessed portion faces away from the spindle.
PurelyPMD
May 5, 2016 04:57 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mcgarnicle
Sep 24, 2015 07:18 PM
