Rear end questions HELP
Old Oct 10, 2001 | 08:48 PM
matty350TPI's Avatar
Ok so I have this 9 bolt sitting in my garage that has 3.45 posi and disks.....its sweet now the problem is that it has the first style brakes. I have drums now, will these brakes do any better? if I use my parking brake regularly will they work ok? Can I later on put the new style calipers on on if I want? I just have those worries, other than that I am ready to go get the rear end fixed and put in. Any ideas?
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Oct 11, 2001 | 10:43 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I put those same style calipers on my drum rear & haven't had any problems out of them yet. I did have to change out the E-brake cables though, the ones from the drum brakes don't work/fit on the disc calipers. GM only made 1 style of caliper mount bracket so newer calipers will bolt up in place of the old. I've seen people say you need to change out that prop. valve but, that's your call. My brakes seem to work just fine w/o doing that so I didn't bother.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 11, 2001 | 01:42 PM
iroc5speed's Avatar
you will need new e-brake cables, and the discs will be a lot better than the drums...the proportioning valve will make a difference though.get a new one and it will make a big difference.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Oct 11, 2001 | 09:48 PM
Any one know if I can just bolt up the new caliper in place of the old style calipers on this 9 bolt. I was under the impression I would need to adapt some stuff. Any ideas??
Old Oct 11, 2001 | 11:19 PM
deadbird's Avatar
Engine: TPI 305/ v6
As I stated, the calipers will bolt up directly to the existing mounts, GM brackets are GM brackets unless you're runng sprint cars or modifieds (I used to work for/fabricate this crap for http://www.afcoracing.com/ a few years back) The only thing that may have changed is the disc rotor itself.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
