what suspension mods work? (for traction)
Old Oct 11, 2001 | 11:56 PM
skipsZ28's Avatar
Car: 85 Iroc
Engine: 385"
Do aftermarket lower control arms really help traction? And what about the torque arm? I'd like to get decent tracion without slicks, but while keeping handling of the car relativly the same. Also are subframe conectors helpful?
Thanks for any info.
Old Oct 12, 2001 | 03:18 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Oct 12, 2001 | 07:43 AM
ede's Avatar
ede
SFCs would be my first move then change the pinion angle with the LCA relocation brackets then a torque arm that mounts to the floor pan. as well as boxing everything.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 12, 2001 | 08:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Anything that reduces flexing will help. All the factory parts are designed for a smooth quiet ride.
SFC are a must with the unibody car. They should be the welded in type. Aftermarket LCA with relocation brackets should be next. The panhard bar could be changed at the same time. Air bags in the springs will help. Lastly should be the torque arm such as the one from Spohn. Even stock eliminator cars have to run the stock torque arm so as nice as it is in having one, it's the last thing you should pick up. There's more involved such as springs, shocks and weight transfer but it starts getting too complicated.
Getting traction without slicks will always be hit or miss. All the fancy suspension parts in the world won't help if the tires can't grip the pavement.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
CamaroX84
Sep 2, 2001 09:39 PM
LarsZ28
Jul 14, 2001 09:29 AM
87rustybluebird
May 21, 2001 09:39 AM
Ben Franklin
May 20, 2001 10:12 PM
Curvehugger
May 8, 2001 08:22 PM
