9" + Torque Arm = :(
I have an 83 Z28 with a 9" centre. Now since the center is larger than stock, the torque arm is mounted further outward. It is very close to the floor pan, and would probably rub when cornering or going over bumps on an angle. Are there any aftermarket torque arms that would give me more clearance, or maybe remove the torque arm altogether, and put in ladder bars??
I am at a loss of what to do.
you might want to email steve spohn and see what he can do. that kind of stuff for all types of applications.
www.spohn.net
www.spohn.net
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What 9" are you using? A moser housing should have the mount very close to the stock location.
All the torque arm will do is go up and down with the diff. If it moves sideways then you have some serious rear suspension problems.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I don't think he is talking about lateral movement I think he means since it's closer to the wall of the "hump" (I guess you would call it) since it's closer there isn't enough room for it's vertical movement.
Dont butcher the bloody thing! Hammers are for nails & breaking things.
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
njdaewoo
3inch
njdaewoo@excite.com
383sb engine
smog pump by-pass
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
