9-inch Ford brackets for 1988 Camaro?
I'm building a 1988 Camaro for use in driver's education events on road courses. The rearend is drum brakes and no limited slip. I am planning to install a Ford 9-inch, but I have not been able to locate a source for the spring, shock, trailing arm and panhard bar brackets I need to make this unit work in the 3rd Gen. Does anyone know where I can obtain these brackets?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
New ones? If you can't get them from the dealer then just cut them off an old 10 bolt. How are you planning on installing the torque arm? Changing those mounts over is easy. Trying to figure out how to mount the torque arm isn't worth the headaches. The only way to eliminate it is to go to a 4-link system or ladder bars.
Calculate all the costs to modify a 9" housing then look at the cost of a Currie housing.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
toronto formula
Nov 10, 2015 06:17 AM
