Southside Machine Kit
Old Oct 11, 2001 | 09:54 PM
Killer-Z's Avatar
Was wondering if anyone has had sucess w/the kit? Am I right in thinkin that this replaces the stock torque arm and lca's? Is this kit better than say Spohn adj. torque arm and adj. lca's? Will they clear a dual-cat car? Thanks For the imput later guys Derrick
Old Oct 12, 2001 | 08:14 AM
Killer-Z's Avatar
anyone?
Old Oct 12, 2001 | 04:58 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
I`ve managed a best 60` of 1.46 using them. Stock control arms stay,torque arm goes.No adjustability except at installation
91Z28 406,mini-ram,Track-1s,232/242 roller,Wiseco 9.5:1 pistons,6"Eagle rods,Callies crank,Speed Pro EFI w/ wide band,Weldon 2015,Nitrous Express 150,Turbo350 w/ 10"ATI,12-bolt 373s,Southside bars,Centerline Warriors,28x11.5 ET Streets Best N/A: 11.22,120mph...10.83/128 with 150 shot
Old Oct 13, 2001 | 07:13 AM
91'firebrd's Avatar
You must be just screaming crossing the line with 3.73's at 120 mph.
Old Oct 13, 2001 | 06:40 PM
Mark W. Winning's Avatar
I thought you also ditched the rear lower control arms when you installed the Southside kit???
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Oct 14, 2001 | 12:27 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Goes thru the traps around 6200.The LCA`s stay,but they say the rear sway bar is no longer needed. I left mine off.
91Z28 406,mini-ram,Track-1s,232/242 roller,Wiseco 9.5:1 pistons,6"Eagle rods,Callies crank,Speed Pro EFI w/ wide band,Weldon 2015,Nitrous Express 150,Turbo350 w/ 10"ATI,12-bolt 373s,Southside bars,Centerline Warriors,28x11.5 ET Streets Best N/A: 11.22,120mph...10.41/129 with 150 shot
Old Oct 14, 2001 | 12:34 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Oh yeah,no problem with exhaust clearance. The SSM crossmember is located at the front edge or so of the back seat.It`s way past the cats and the single pipe goes right over it, in it`s stock location. Later,Glen
Old Oct 14, 2001 | 11:17 AM
Killer-Z's Avatar
Yeah but what about the subframe connectors. I know Spohn has separate connectors for dual and single cat cars. Later Derrick
Old Oct 14, 2001 | 10:06 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
The only place where it may be tight is right where the y-pipe turns toward the back of the car before the cats. You have to remove this part of the exhaust to install them anyway,so it can be "tweaked" upon re-installation. There`s plenty of room for both cats though.
Old Oct 15, 2001 | 07:22 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Have you any pics of this set up on a 3rd Gen? I am dying to see how this looks!
'86 IROC ZZ4
Holley 750 dp, Shorty Headers, BW POSI 3.27 rear, Southside sfc's, Probuilt 700r4, Hurst Dual Gate Shifter.
Best Run 13.8 @ 100mph- far more to come!
London-England (Brothers In Arms)
British Firebird/Camaro Site
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
