Swaybar bushings?
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Swaybar bushings?
Does anybody know what aare the GM part numbers for the front swaybar? I unbolted and measured the bar diameter where the bushing mounts. The size is 34mm. If I measure other spots on the bar, it measures 36mm. So if I get 36mm bushings, will they fit my bar?
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You measure in the spot directly where the bushing is on the bar,, that is what size you order. As for sizes & p/n's,, check my sig.
Go to 'front suspension' under the firebird section & I believe it's #9 for sway bar sizes/p/n's
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited October 11, 2001).]
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
they are 36mm bushings.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
I just removed my front bar and measured it with a caliper. Where the bushings are, it measures 1.41" or 36mm.
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
Car: 1992 Z28
Engine: 355
Are your original bushings "blown out" ? The 1LE sway bar bushings and WS6 sway bar bushings are one and the same.
92Z28
89GTA
92Z28
89GTA
camaro1185
Oct 26, 2015 06:51 AM
