Tire sizes?
Old Oct 24, 2001 | 07:41 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Tire sizes?
Is anyone using 255/50/zr16's? I am considering moving up from the 245's. Will have any clearance problems with the rear wells or front inner wells? I plan on using the stock 8' rims.
Thanks,
BILL
91 Formula 305 TPI Stock
88 Formula 350 TPI Stock
Old Oct 24, 2001 | 08:18 PM
Ezey Go's Avatar
Im running 255/50/16,But I dont know if they are zr rating.They fit just fine on my car.Later
Old Oct 24, 2001 | 11:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The only problem you will have is the speedo will read a touch slower at higher speeds
My camaro is 2mph off(slow) at 50.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 25, 2001 | 06:51 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
255 50R16 BFG Drag radials. I need to put poly bushings in the panhard bar to prevent rubbing around coroners.
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
