Keep blowing out rear shocks
Old Oct 23, 2001 | 06:47 PM
PonyKillerZ's Avatar
I went through the original rears...then some comp engineering drag 3-way adj....then some more stock ones...
the roads are rough here in Michigan...but can they be that rough?
"Only ricers do fly-bys"
Old Oct 23, 2001 | 07:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you need some springs... your shocks may be having to do too much work.
ICON Motorsports
Old Oct 24, 2001 | 04:02 PM
I have Eibach springs...
only a couple months old...
stret strip springs...maybe not good for daily driving
Old Oct 25, 2001 | 09:53 PM
i have comp engineering struts up front to...
they told me the set up would last...I guess it doesnt..
could it be the how flexable the srings in the rear are or what they are made of? the rear is up in the air quite a bit...when i slam on the gas tho...the rear drops down (for grip they said) i think its the fronts allowing it to do so.
I dont know what do you guys think...
eibach drag springs...comp engineering front n back...
rears had to be replaced becasue they blew out...now my new stock ones i put in a month ago are out again...
Help
Old Oct 26, 2001 | 06:44 PM
Z28DJP1987's Avatar
Still have the original Bilstein Shocks on my 1987 IROC and its still solid like a rock.
You have problems,like miss a few potholes.
Old Oct 28, 2001 | 02:25 PM
OLDYELLR's Avatar
Car: '85 IROC
If you have Eibach springs, you probably need shocks that will work with competition springs. Konis should do it. They have a lifetime warranty.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
86White_T/A305
Aug 17, 2015 12:16 AM
