What size rims do I have? And other tires questions. Please answer!
Old Nov 3, 2001 | 07:41 PM
Xenodrgn's Avatar
Ok, my tire size is 195/60R14's, but when I measure the rim it comes out being 15 inches??? I thought 14 ment rim size?
Also, how wide are my rims, and what's the widest tires I can put on them and have it look good and normal without ballooning? What do I have to do to get them to fit? I was thinking of getting BF Goodrich radial comp TA's, something like 245/50 R14?'s work?, what can you guys say about them? I handle really pretty well on the street as it is, but I'm looking for something thats going to keep me on the road in the rain... it's scary how easily I can slide... today I was just rolling around a soft turn on a slight decline and my car totally lost all traction, so I definatly need wider better tires... Right now I'm using Michellin WeatherWise ones... they suck!!!
Thanks for your time...
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Nov 3, 2001 | 08:24 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
You are measurng the total outside diminsions of the wheel. Wheels are not sized that way. To measure correctly you must measure the wheel without a tire on it. You measure the inside dimension where the tire bead seats, not the outside dimension. Width is measured the same way, on the inside surface of the wheel where the tire bead seats, not the total outside width of the wheel.
I don't know for sure about the width of your wheels.
Your wheels are probably 6" wide, but may be 7" wide.
On 6 inch wheels, about a 225 series tire is as wide as you can go before the tire starts "balooning" out and the tread starting to bulge in the center. A 235 would be max.
On a 7 inch wheel a 235 would be the best widest width and a 245 max with some bulging.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited November 03, 2001).]
Old Nov 3, 2001 | 08:40 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
</font>
stamped on the rim somewhere usually on the ring is the size of the rime 14 x 6 JJ.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
g.l.mos
Aug 22, 2015 12:02 AM
knight72
Aug 10, 2015 09:32 PM
