Distinct Side by Side Sway (Low Spd), Vibration (High Spd), funny rattle (bumps)
Old Nov 17, 2010 | 07:54 AM
Jerome Casi's Avatar
Car: 1989 Camaro RS
Engine: 355
Transmission: 5 speed Manual
Axle/Gears: Stock
I think I am having some issues with the rearend suspension system. When I hit a bunch of bumps in succession I get a series of loud noises like something is loose. At about 10mph the car does a funny side to side distinctive shake, then when I hit 78-80, i get a serious vibration coming from the back as well.
I new to the camaro, did some searching on here and couldnt find much that met the criterea of problems I am having.
Tips on what to check, pictures if available as I am new to the terminology for the Camaro, but capable of working on things.
Thanks,
Old Nov 17, 2010 | 08:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Distinct Side by Side Sway (Low Spd), Vibration (High Spd), funny rattle (bumps)
As for the low speed sway and high speed vibration, look for either a bent wheel or a bent axle.
RBob.
Old Nov 17, 2010 | 09:40 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Jack it up and check your Wheel Bearings. Another thing you might look at is your Strut mounts.
E Rod
Aug 28, 2015 05:17 AM
Fronzizzle
Aug 17, 2015 02:52 PM
jackhammer
Aug 15, 2015 10:04 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
