anyone know where i can get bushings for a Lakewood adjustable Panhard Bar??
Old Nov 7, 2001 | 01:44 PM
Fastcamaro87's Avatar
bought a new Lakewood adjustable panhard bar off e-bay for $20 but it doesnt have bushings, anyone know the part # or what bushings will fit?or where i can get them? thanks
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 7, 2001 | 04:57 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I ordered a Lakewood Adjustable Panhard Bar a few months ago from Jeg's and it arrived with both ends of the box blown out and the bushings missing.I called Jeg's and they connected me with someone at Lakewood.Lakewood sent them to me directly and without charge in about three days.
They might charge you for 'em since you didn't buy it new, but I'm sure they'll send you a set.
Adj PH Bar is part#20440
Go to Tech support at Lakewood:
http://www.mrgasket.com/maildirect/h...s/Lakewood.asp
or call (216) 688-8300
which is the tech service line for Lakewood,Mr.Gasket,Hurst,Accel and Hays.
hope this helps
-Rich-
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Antips16
Oct 30, 2015 06:42 PM
camaro1185
Oct 26, 2015 06:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
