caliper questions
Old Nov 8, 2001 | 10:27 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
caliper questions
how do you know when you caliper is "bad"? i can't get the rear brakes to work. the front wheels are extremly hot and a strong burnt brake pad smell coming from the front. the brake pedal has a spongy feel to it. i have since replaced the master cylinder, prop valve, and bled the system(fresh fluid in the whole system). brake pedal is still spongy. No brake light. well i think my rear calipers are bad? i am going to replace the hoses next and hope for the best. any suggestions? comments? any help is appreciated
why the hell am i going throught this crap???
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
[This message has been edited by mystikkal_69 (edited November 08, 2001).]
Old Nov 8, 2001 | 11:59 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Your rear calipers could be bad causing your front brakes to do all of the work.
This is a common problem in these cars.
There is a "self adjusting" mechanism in the rear calipers to take up the slack as the pads wear. The self adjuster is enabled when you apply the parking brake. Unfortunately the System wasn't designed particularly well. The spring isn't strong enough and the system is prone to sticking due to rust, and dust build up. GM had a recall going (8 years) to replace the spring for manual transmission cars because the parking brake wouldn't hold the car.
Anyway, if the parking brakes are not applied often enough to keep the system free and working properly the parking brake won't hold the car and the self adjusters don't function either. When this happens the rear brakes lose braking power, and the brake pedal has excessive travel.
Old Nov 9, 2001 | 05:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The recall doesn't just replace the spring, it replaces the entire actuator assembly.
Old Nov 9, 2001 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Apparently the rear brakes can be a problem; however, I use the e-brake on my 5 speed every time I pull into the garage, and I've never experience any difficulties.
JamesC
[This message has been edited by JamesC (edited November 09, 2001).]
Old Nov 9, 2001 | 07:13 AM
Car: 1988 IROC-Z
i agree with you IROVKZ4me that the fronts are doing all the work. i'm sorry but i have seemed to have forgot to metion that i have the 89' and up PBR setup and is "supposed" to be better than the 88' and earlier setup (screw-in type). i am really getting tired of this......non fuctioning rear brakes.
i'm starting to think about going drum brakes..... i never had any problems with drums brakes.
[This message has been edited by mystikkal_69 (edited November 09, 2001).]
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Genopsyde
Nov 11, 2015 10:46 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
