PLEASE HELP QUICK: TORQUE ARM REMOVAL
Old Nov 10, 2001 | 09:25 AM
iroc5speed's Avatar
ok, I'm in the middle of a clutch swap and I have to remove the tranny. the torque arm has to come off, but I didn't know you had to take the springs out. I have the pinion jacked so I could take the driveshaft off. I am supposed to take the springs off but is there a way to take off the torque arm without taking the springs out? I don't have another set of jackstands to set the rear on to take them out, and my floor jack is under the tranny. How can I do this?
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Nov 10, 2001 | 01:06 PM
Hulk0202's Avatar
I think you just have to brace the front with something to keep it from swinging down, then unbolt it at its front mount. As long as you have something under it like some block or anything that will hold it. If it does drop itll probably just be a bitch to push back into place.
Old Nov 10, 2001 | 03:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You don't have to take the torque arm off the remove the trans.
You do however need another set of jack stands. Jack the car up however high you need it, and support the frame with jack stands. Then let the rear end down as far as it will go, and jack it back up an inch or 2, just enough to unload the shocks. Support the axle tubes - the tubes themselves, not the shock brackets, or the pumpkin, or anything else - on a pair of jack stands. Make sure it's supported just above the point at which the shocks are fully extended.
If you do it this way, you get to leave the TA in; and there's so little force on it that you can just grab it with one finger and move it up and down wherever yo need it to go.
ICON Motorsports
Old Nov 10, 2001 | 06:51 PM
Andy89RS's Avatar
Every time I've removed the tranny I did it with the rear wheels on ramps. This puts no load on the torque arm, so when you remove the torque arm bushing from the trans it won't try to slam into the trans tunnel or the ground. To reinstall it you just need to push it inward toward the trans, it'll still be aligned up/down.
Member Southern California 3rd Generation F Bodies
Co-President Golden State 3rdgens
AOL IM: Andy89RS
Old Nov 10, 2001 | 07:12 PM
iroc5speed's Avatar
I got it guys, I just took off the rear bolts and slid it off. Thanks for your help. Now any ideas about bellhousing to trans bolts that are torqued way too much that don't want to mocve after pb blaster and a wrench with a cheater bar? They're torx bolts( I hate those in tight places)
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ducati900ss
Sep 2, 2015 09:05 AM
zayne0
Aug 24, 2015 07:22 PM
