Poly Brushings
Old Nov 11, 2001 | 09:04 PM
Buck268's Avatar
Poly Brushings
How exactly do these help improve performance?
Old Nov 11, 2001 | 09:23 PM
Stell1579's Avatar
they are harder and give less. they donot alow for asmutch flex as regular rubber. they will make everything feel tighter.
-Stell
1988 Pontiac Trans Am. 305 TPI Mods=MSD 6A+Coil+Wires, K & N, SLP AirFoil,180 Thermostat, Cold Air, Hooker Aerochamber Catback
1974 Dodge Charger , Currently restoring but has a 318 with Crane Cam, Carter AFB 4BBl Carb sitting on a Weiand Stealth Intake
RIP 1988 IROC-Z
Old Nov 12, 2001 | 09:17 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The poly doesn't deflect like the stock rubber , so it acts like more of a solid pivot point,less likely to twist around.
This allows the suspension to move at the points it was designed to pivot at, instead of just compressing (or binding) in rubber.
The Delrin and aluminum bushings I'm using are even less likely to deflect or bind than the poly, but they are a little noisier.
-Rich-
Old Nov 12, 2001 | 02:08 PM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
<font face="Verdana, Arial" size="2">Originally posted by Buck268:
How exactly do these help improve performance?</font>
Let me ask what aspects of performance that you're trying to improve. Poly is a good choice in some applications (sway bar bracket bushings), OK in others (sway bar endlinks, one end only in LCA's), and generally a poor choice in some (both ends of LCA's).
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old Nov 12, 2001 | 02:56 PM
coach's Avatar
Poly bushings are supposed to last longer than rubber bushings. I've taken out end link bushings that were so brittle that pieces had already fallen off. Poly bushings aren't susceptible to deterioration from salt(air, road), oil, grease, etc(at least that's what I have read).
I've personally have had swaybar bushings, end links, and lower control arm bushings replaced with poly bushings, and I did notice an improvement in steering feel. The downside to poly bushings is that they tend to squeek if not lubricated. But for me, that is a small trade-off for the performance you gain.
Old Nov 12, 2001 | 09:23 PM
Buck268's Avatar
How much would a set cost me? and just as important, how hard is it to install?
Ed1LE
Sep 30, 2018 09:14 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
