Spohn LCA brackets, which hole to use?
Old Nov 12, 2001 | 11:51 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Since I lowered my car I got LCA relocation brackets from Spohn. There are two different holes to mount the lower control arms. Right now I'm using the upper hole and the LCAs are parallel to the ground. Would there be any advantages or disadvantages in using the lower hole? That would make the LCAs not parallel to the ground, but lower at the axle than at the frame.
91 Z28
Come see The Vicious...
Old Nov 13, 2001 | 12:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Using the lower hole will give you a little more traction during launch, but I find it tends to make the car more prone to oversteering. My car isn't lowered though, which makes the angle on the lowest hole fairly steep.
[This message has been edited by Apeiron (edited November 12, 2001).]
Old Nov 13, 2001 | 01:14 AM
BTS88IROC's Avatar
I would say switch it to the bottom hole if you are still having problems with traction or hooking up off the line. If not, then I wouldn't worry about it to much.
Old Nov 13, 2001 | 07:25 AM
82camaro's Avatar
Car: 82 camaro SC
Since you are lowered, I would try the bottom hole. If you don't like you can always change it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
Jorlain
Oct 8, 2015 01:57 AM
L0tuS
Oct 4, 2015 08:07 AM
Nick McCardle
Sep 10, 2015 08:36 PM
