specs...
Old Nov 13, 2001 | 09:12 AM
bored_blitzen's Avatar
specs...
i was wondering if anyone could tell me the stock specs for the thickness of a sway bar on all model camaros in about the '86 area. (should be the same for all 82 - 92) and i was also wondering if anyone could tell me the stiffness on stock springs for all models? thanks a lot.
Old Nov 13, 2001 | 10:33 AM
82camaro's Avatar
Car: 82 camaro SC
Lots and lots of different size sway bars.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 13, 2001 | 01:39 PM
i am aware that there a lot of different size sway bars.. i'm just tryin to figure out what the stock sway bar sizes are.. not the aftermarket ones you get and put on.. stock, as in the ones that came directly from the factory..
Old Nov 14, 2001 | 11:38 AM
iroc5speed's Avatar
stock on an IROC is 36 mm front, and 24 mm rear(close to 24, I can't remember the exact # but I think I remembner 24 mm). If it's not an IROC they are smaller
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Nov 14, 2001 | 03:45 PM
86Chicken's Avatar
The V6s got 34mm front / 18mm rear. I think some of the lesser-optioned V8s got those, too.
Dale
paulmoore
May 10, 2014 11:05 PM
skyhigh4by
Feb 26, 2014 02:41 PM
paulmoore
Jan 26, 2014 08:30 PM
34blazer
16
Apr 5, 2011 01:29 PM
