Putting on a new front end.
Old Nov 9, 2001 | 07:01 PM
camaro6spd's Avatar
As some of you know i hit a deer and bad things happened. Now, it is dark and even if it was light i would still ask the same question. I think my crossmember is damaged, it looks fine except for where the bottom of it hit a rock that was 1/2 buried in the ground, The crossmember is hollow and looks like it dented in some but other then that and the LCA(drivers), a f'd up nose, fender and the such, would it be possable to replace the crossmember or is is fine? Anyone live around Clinton NJ that would come take a look, we don't know any good honest body shops around here.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 9, 2001 | 07:03 PM
SoCo80p's Avatar
from the sounds of this post and the other the front end is totally screwed, onlything you can do, (to do it RIGHT) is get an entire new subframe and swap it over, then everything will be as stright as it was before.
Old Nov 10, 2001 | 08:53 AM
ede's Avatar
ede
before i went to the trouble of swapping the front K member i'd take it to an alignment or frame shop and have then set it up on their jig to see how far out if any it is. shouldn't cost much and may save a lot of effort.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 10, 2001 | 01:10 PM
camaro6spd's Avatar
yes, i know, i am justing looking at all my different options here....buying a 91-92 is what i a favoring right now. The cost of getting the thing right, aliment, tire, bentparts, new body panels, pain etc etc. For a little more I could get a 91-92 with a tranny or motor problem and swap in mine.
Old Nov 14, 2001 | 04:44 PM
camaro6spd's Avatar
Ok here is some new observations about the car. I have it jacked up off teh ground and on stands like 3 feet off the ground(the more the better) and looking at it....not taking any mesuments or nothing... both Control arms almost look inline and where they should be(based off the right side which is not f'ed up). Now the drives side wheel is severly toed out(i think, maybe in)...maybe it is just out of wack, is there any way for me to try and adjust this myself to see if it can be fixed this way and i can drive it to a shop to dial it in(about 5 miles from me). Also the crossmember is dented in on the bottom but looks to be all inline and stright. I have about 10 photos, but i have to finish the roll and then develop them....then you will see them here. Any special areas you would like photographed to help determine damage.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways........Wrecked by a deer.
Looking for a 1995 Honda CR125R in NJ or PA. I have one for sale...RRP Sleeve Job, Vertex Piston, New Sprokets and a x-ring chain, new botom end with crank...etc etc
look here
http://www.classifieds2000.com/cgi-cls/ad.exe?P1+C18+R100004616
AIM: IROC 5spd
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
